How to edit config/database.yml
(Tumi) #1
"Your config / database.yml file uses the default localhost server name. Modify it to use the name of your site’s server. " Btw should i change it ?.
My question is how to edit database.yml ? i Dont have a config directory
Also i dont see a docker directory in var, where is this ?
(Felix Freiberger) #2
This sounds like your are using an unsupported installation method. Unless you’re trying to develop Discourse or plugins for it, follow these instructions to install:
https://github.com/discourse/discourse/blob/master/docs/INSTALL-cloud.md
