How to edit hamburger menu items?
(Aagat) #1
Is there any way to edit/delete/rearrange menu items in hamburger menu next to profile picture on top left of the screen?
(Jeff Atwood) #2
Not possible at this time, sorry.
(Spero Koulouras) #3
Is DOM manipulation from some Javascript a bad idea? I just did something like this and it appeared to work, but something could be very broken under the covers. The javacript was placed in top of pages
x=document.getElementById("site-map-dropdown").getElementsByClassName("latest-topics-link");
x.insertAfter(z);    // z contains the node to insert with my custom functionality
(Kane York) #4
Yes, it would be better to change the Handlebars templates that the dropdown is rendered from.
(Spero Koulouras) #5
I thought this was too easy … :slight_smile:
(Aagat) #6
I am kinda disappointed but I guess hacking template/rendered page is my only option here.
How does modifying templates affect my upgrade process?
(ljpp) #7
Is there an easy way to modify the Burger menu item “FAQ” into something else. I am using the FAQ page for the written forum rules, rather than questions and answers. Therefore I would like to modify the FAQ into Rules. Or maybe I can add an item to the burger?
(Logan Mathews) #8
There is a text.replace feature in the admin panel which can/should be used for renaming the faq to rules.
Sent from iPhone
(zqcolor) #9
better one to change hamburger menu found in other forum
https://www.sitepoint.com/community/t/a-simple-discourse-plugin/116302/5
< script type=‘text/x-handlebars’ data-template-name=’/connectors/site-map-links/shop’ >
<li><a href="http://www.example.com/shop/" title="Some Amazing Club Shop" class="shop-link" target="_blank">Shop</a></li>
to Admin -> Customize -> CSS/HTML -> < /head >
(Jeff Atwood) #10
I believe @eviltrout added better support for this yesterday, at least as far as adding hamburger menu items.
(Robin Ward) #11
Yes you can add additional hamburger menus by adding a customize > CSS/HTML > /head like this:
<script type="text/discourse-plugin" version="0.4">
  api.decorateWidget('hamburger-menu:generalLinks', () => {
    return { href: 'https://eviltrout.com', rawLabel: 'evil trout' };
</script>
Quick translation for a few custom menu items?
(zqcolor) #12
great! thanks a lot for fast response
(Sebastian) #13
cool, very easy. So I added a “contact” link, but it is put into the group with links that pertain more to content in the forum, any way to put it down next to FAQ etc.?
(Robin Ward) #14
There was no way to do this, so I’ve added it:
You can add a link in a similar way, just target footerLinks instead of generalLinks:
  api.decorateWidget('hamburger-menu:footerLinks', () => {
</script>
Discourse Vincent theme
#15
If there is an uneven number of links in the section above the layout will be messy.
Before footer links I forced in links in general links and added the border myself. I solved this problem there with a dummy link to fill out the space but it could probably be fixed in a more nice way.
(Blumiere) #16
I am so happy that I found this thread. I had no idea this was possible and was previously using a rather unsightly bar of links at the top of my installation.
I have to wonder though, is there other javascript that can suppress existing menu items? That would allow full customization with this.
(Robin Ward) #17
You should be able to use CSS to hide menu items that you don’t like.
(Blumiere) #18
There we go. Thank you for that. :slight_smile:
(Vinoth Kannan) #19
flatten function added for applyDecorators of footerLinks same like generalLinks. Else custom footerLinks not working in some cases.
(Blu McCormick) #20
G’day!
This code is perfect. Just what I needed. I would really like to add my links to the very top of the hamburger drop-down mobile menu in capitals where the FAQ is. Is there a way to do this? I am thinking that I just change the code [___]Links:
55 PM
The last drop-down menu section is footerLinks
The third section from the top is generalLinks
What is the top section called?
Thanks so much.
Question on header/menu
