How to edit "Title seems unclear, is it a complete sentence"
(Bank Live) #1
I use Thai web. if use title “มาดูวิธีการทำเกียร์ให้หายสงสัยกันครับ” it is show "Title seems unclear, is it a complete sentence?"
But if use “มาดูวิธีการทำ เกียร์ ให้หายสงสัยกันครับ” i can. How to i can edit.
I already enable allow uppercase posts.
Thank you.
(Christoph) #2
Search for “sentence” under Customize - > Text Content. Not sure why there are several identical copies but you’ll figure out which one it is…
BTW: Searching for “Title” wont work because that part of the message is itself a variable and hence omitted from the one you’re looking for.
(Régis Hanol) #3
Despite the title, I don’t think @Bank_Live wanted to know how to edit the string “Title seems unclear, is it a complete sentence”, but instead how to prevent it.
@Bank_Live, have you tried lowering the “title min entropy”?
(Bank Live) #4
@zogstrip can disable it or not?
(Sam Saffron) #5
Set it to 0 to disable
