How to execute db:drop db:create db:migrate?
(Ricardo Viteri) #1
How do I execute the following command?
bundle exec rake db:drop db:create db:migrate
(Sam Saffron) #2
Why are you trying to destroy all the data in your database?
(Ricardo Viteri) #3
Thanks
(Ricardo Viteri) #4
Hi, any pointers on how to accomplish this?
Cheers.
(Arpit Jalan) #5
Since we have switched to Docker based install, it’s not possible to run the commands directly on server.
To delete a database, follow the instructions under header Example: Delete a corrupted database, in this guide:
(Ricardo Viteri) #6
Hi @techAPJ, I just nuked the database as per your instructions but everthing got restored. Is there a way to delete all the data and leave everything else?
Thanks
(Kane York) #7
What do you mean by that?
Was the container running when you tried to do this…?
(Ricardo Viteri) #8
@riking Yes, everything was on.
(Jens Maier) #9
The FAQ is a bit outdated:
In the default install, the correct path is shared/standalone/postgres_*, and there’s an echo left over from, I’d assume, testing the command. :slight_smile:
(Jeff Atwood) #10
Ok if that is so @techAPJ can you update it to be accurate with current versions?
(Kane York) #11
I updated it to use /var/discourse/shared/standalone.
