How to get rid of the millisecond feature thing
(Nathan Cole) #1
Okay, so I just setup discourse forums for my server, and I was wondering how to get rid of this millisecond feature to the left of the page as seen here.
Milliseconds
Thanks
Question on Admin Area
(Rod James) #2
Custom CSS
.profiler-results.profiler-left {
display: none;
(Nathan Cole) #3
Thank you, and for some reason when I go to organize the categories the option isn’t there is there a way to add/enable this?
(Rod James) #4
I’ll leave that question for someone more knowledgeable on categories.
(Nathan Cole) #5
Nevermind, I figured it out. It was fixed category positions in Basic Setup!
Thanks for the help!
(Sam Saffron) #6
Remove yourself from the developer role, see:
Once you change the setting be sure to rebuild the container.
(Allen - Watchman Monitoring) #7
Or, toggle it on & off using altp
(Mittineague) #8
Or ignore it, it isn’t like everyone can see it
(Allen - Watchman Monitoring) #9
Well, I find it gets in the way at times, especially when typing, and once we’re in the compose box, alt-p doesn’t work anymore.
(Felix Freiberger) #10
To add even more ways to hide the mini profiler, you can also fully prevent it from loading:
