How to Hide Categories on Homepage:
(James) #1
For communities that focus on tags more importantly than categories, this is how you can hide the category table on the homepage/latest. This is also helpful if you have a sidebar and there’s not much space on topic lists.
Go to your theme settings and paste this in common CSS
td.category {
    display: none;
th.category.sortable {
    display: none;
th.category {
    display: none;
For mobile, paste this into the mobile CSS section:
.topic-list .topic-item-stats .category {
    display: none;
Hope this may be useful to some! :slight_smile:
I appreciate @awesomerobot for motivating me to further learn CSS to discover little hacks like this.
Thanks for the hand @Stranik
(Jeff Atwood) #2
This would be an exceedingly rare scenario.
(James) #3
Correct, but there are always edge cases. I don’t want to leave out those who are too shy or afraid to ask for these questions because the majority don’t require them.
(James) #4
Any idea why this doesn’t work for mobile?
(Evgeny) #5
Other templates are used for the mobile phone. Try to put, for example, User-Agent Switcher - Opera. Or change the value of general.useragent.override to do research and see what css is used in a particular case.
(James) #6
That’s a very useful tool, which led to the finding of this piece of code which will hide categories on mobile, too!
    display: none;
Just add this to the mobile CSS of a theme only.
#7
This should be added to OP!
Why isn’t this post a wiki?
(James) #8
There isn’t anything more to add to the topic. The code is there for desktop and mobile.
