How To Hide the button of logged in users?
I have added a button Join Now using the Custom Header Links theme component.
I want to show this button to the non-logged in user and want to hide it to the logged-in members.
I have tried adding this code:
#top-navbar {
display: none;
.anon #top-navbar {
display: block;
But it is not working, please help me…
It should work in theory (if you used the right class and id), can you provide a link to your forum?
here is the link https://businesscomputingworld.co.uk/
I see no #top-navbar in your HTML code, so try replacing this CSS id by .custom-header-links.
I have replaced please check now
It is working now, can you please help to add + icon as added in the New Topic button if discourse?
The plugin doesn’t have this feature currently, but it is possible to use another plugin and doing a bit of hacky CSS:
Replace your current plugin with this one: Iconified Header Links
Remove existing icons and create a custom one like this:
As for the icon identifier, set “plus”.
Then in your theme customization settings, add this custom CSS (replace “Subscribe” by whatever you want):
.d-header-icons .vdm a {
    width: auto;
    height: 30px;
    margin-top: 6px;
    color: #222;
    background: #e9e9e9;
    padding: 6px 12px;
    box-sizing: border-box;
    svg {
        font-size: 1.1487em;
        width: 1em;
        margin-right: .45em;
        color: #646464;
        transition: .25s;
        margin-top: -1px;
    &:after {
        content: "Subscribe";
        transition: .25s;
        margin-top: -1px;
    &:hover, &:focus {
        background-color: #919191;
        color: white;
        svg.d-icon {
            color: #e9e9e9;
It will look lke this:
Hover:
Okay, thanks for your help
I have added the CSS and also add those codes to show the button only for logged-in users. But I am not able see Search icon and the menu icon. Seee here Screenshot by Lightshot
And the button is also in the right side of Log in button, I want to add it in left.
I see. Let me check that in a few hours, maybe I can figure out another way.
And I also want the same look as Log in button has, same size text, same color, same font if possible.
Go in your theme customization, </head> tab, and paste this:
<script type="text/discourse-plugin" version="0.8.20">
if(api.getCurrentUser() == null) {
    const { iconNode } = require("discourse-common/lib/icon-library");
    api.decorateWidget('header-buttons:before', helper => {
        return helper.h('a.widget-button.btn.btn-primary.btn-small.custom-header-button.btn-text', {
            href:'https://businesscomputingworld.co.uk/t/how-to-post-content-on-this-site/39910',
            title: 'How to post content on this site'
        }, [iconNode('plus'), helper.h('span.d-button-label', 'Subscribe')]);
</script>
In your CSS tab, paste this:
.custom-header-button {
    margin-right: 7px;
    padding: 6px 10px;
It will look like this:
And won’t be shown if the user is logged in.
It is working thanks…
I have added self in the custom links plugin but it is optning the button in the new tab. I don’t know why?
This is what I added: Contribute, Register to create topics, https://businesscomputingworld.co.uk/t/how-to-post-content-on-this-site/39910, self, keep
Can you help me?
I want to hide this buttom for a specific group in my discourse forum? Monthly group…
I used this group
body:not(.primary-group-Monthly) .custom-header-links {
display: none;
Replace this:
By this:
title: 'How to post content on this site',
target: "_self"
(don’t forget to add the comma after the first line)
I made the button so it is hidden when you’re a logged-in user. So I don’t understand how it would appear if a user is in a group (since it means that the user is logged-in)…
Now I don’t need to hide button from the logged-in users, I want to hide it from Monthly group users?
Can you share the code to hide the button created using Custom Header Links plugin?
What is a monthly group? Is it a custom group you created or something managed by Discourse?
It is created by me for my paid members
If you want the button visible for everyone but this group’s members, replace:
By:
const user = api.getCurrentUser();
if(user.groups.includes("primary-group-Monthly") == null) {
            target: "_self"
Make sure that “primary-group-Montly” is the exact group name.
It seems that no group class is added in <body> so I’m not sure that it’s possible to hide it with CSS only…
