How to hide timestamps in html mobile output?
(Kreg Swam) #1
2017-03-03 07:09:36 UTC #11
How to hide timestamps in html mobile output? (Not css hidden). Want to find elegant way to hide “2017-03-03 07:09:36 UTC” strings
(Régis Hanol) #2
Why would you want to do that? It’s used by the application to show the relative date.
(Kreg Swam) #3
I push many posts via api. And I think its suspicious for search bots to have post time stamps too close with each other(several posts per second). So want just prevent them from output.
(Régis Hanol) #4
Why don’t you set a different “created_at” date when pushing a post?
(Kreg Swam) #5
found your post https://meta.discourse.org/t/set-the-date-of-a-new-topic-via-the-api/43308/3?u=bitsw. Is “created_at” work now?
Anyway dealing with “created_at” needs to manage dates. I mean need to gather all posts timestamps and recreate them with valid intervals. Hide timetamp is most simple solution for my case. Is it possible without rebuild app?
(Régis Hanol) #6
Yes, it should work now.
No. You can only hide that value if you override the .erb file in a plugin.
