How to http request topics created_at or bumped_at greater than x date?
(Jonathas Spalding) #1
Is there a url query string or something that can be used to request topics created_at or bumped_at greater than x date?
(Jeff Atwood) #2
For created at, did you look at search options? Press search then options, read through what is shown.
(Jonathas Spalding) #3
Yes, I did look at search options but none of them return only the topics newer than a specified date.
I’m trying something like: https://meta.discourse.org/latest.json?state=tracking&created_at=2015-10-19T23%3A20%3A49.115Z
Order and min/max age is not what I’m looking for. This is what I can see as search options:
(Jeff Atwood) #4
Ok, just wanted to make sure you were aware of that. I think you will need to use a Data Explorer query to get what you want.
(Jonathas Spalding) #5
Thanks but I’m afraid that I will not be able to do an http request on a Data Explorer query, right?
I should have been more specific as I need to be able to get a json from an http request with that info.
I’m updating the topic title to be clearer.
