How to increase avatars size on Latest without making them blurred
(Joe) #1
:loudspeaker: :warning: This guide is now deprecated in favour of the theme component Avatar component. You can still add the CSS to create special effects :warning: :loudspeaker:
In order to avoid blurry avatars, you need to override the template for posters-column.raw and change the size of the avatars to “large”. Add this to the </head> in your desktop theme
<script type="text/x-handlebars" data-template-name="list/posters-column.raw">
<td class='posters'>
  {{#each posters as |poster|}}
    <a href="{{poster.user.path}}" data-user-card="{{poster.user.username}}" class="{{poster.extraClasses}}">
      {{avatar poster avatarTemplatePath="user.avatar_template" usernamePath="user.username" imageSize="large"}}
    </a>
  {{/each}}
</td>
</script>
This will make all the avatars larger:
You can then use CSS (in your desktop theme) to reduce the sizes of all the avatars except for the latest post:
td.posters {
  display: flex;
  align-items: center;
  img.avatar {
    height: 25px;
    width: 25px;
    &.latest {
      height: 40px;
      width: 40px;
You can stop here but I feel it’s a little bit messy so you might also want to shift the latest poster’s avatar to the far left to make things a little bit more uniform like so:
For this you’d have to use this bit of CSS instead
td.posters {
  display: flex;
  a.latest {
    order: -1;
    img {
      margin-right: 4px;
      height: 40px;
      width: 40px;
  img.avatar {
    height: 25px;
    width: 25px;
Avatar size and shape
Increase avatar of Latest.
Increase Avatar Size to 120x120 pixels
Center td.posters container
CSS help please- resizing avatar in posts from 45 to 120
How to change topic avatar size?
How to increase Discourse avatar resolution with JS?
