How to like a topic using the Discourse API
(sleep) #1
Hey all.
How to like a topic about Discourse Api?
(cpradio) #2
Send a request to https://your_forum_url/post_actions sending the post id as id, and the post_action_type_id of 2.
That will in turn like the particular post for the give discourse username and api_key
(sleep) #3
Please tell me how to get the post_id ?
(cpradio) #4
The topic json will have it, or you can view source and see it as a data attribute.
(sleep) #5
Thank you for the help.
(Stefan Milenkovic) #6
hi all,
i tried to like post with {
post_id : id,
post_action_type_id : 2
but still getting 400 bad request.
do i need also to send topic_id?
thanks!
(Blake Erickson) #7
nope.
Do you need to provide your api key? I was just able to get it to work with:
(Stefan Milenkovic) #8
i already have cookie and X-CSRF-Token.
the same calls i made for creating topic and replying to topic.
But when i used same logic for liking comment, it is not working.
(Blake Erickson) #9
Make sure you aren’t trying to like your own post :wink:
How do you know what the post id is?
Can you open up your chrome dev tools and like a post and see what the post id is? Then undo your like. Then try again through the api.
(Blake Erickson) #10
its id not post_id
(Stefan Milenkovic) #11
so i looked in dev console, i thought i was missing “flag_topic”:false
but that doesn’t solves the problem
here it is how my data looks like :
“post_id”:6519,“
post_action_type_id”:2,
“flag_topic”:false
and the same looks in dev tools, but when i try with API
it wont work.
(Blake Erickson) #12
“post_id” needs to be changed to just “id” still.
so it should look like:
post_action_type_id: 2
(Stefan Milenkovic) #13
ah, ok :slight_smile:
not exactly the same, just like you said.
id instead of post_id
thanks!
(Stefan Milenkovic) #14
ok, now data looks like this,
still no luck :slight_smile:
“id”:6516,
“post_action_type_id”:2,
“flag_topic”:false
even with the id, it won’t work.
(Stefan Milenkovic) #15
it looks like data format is a little bit different with API and from dev console
when i send through the API i use JSON.stringify({
post_action_type_id : 2,
flag_topic:false
and in the payload looks like this {“id”:6518,“post_action_type_id”:2}:
and when i look payload of call of forum in console it looks like this :
post_action_type_id:2
flag_topic:false
what data is expected on server, json?
(Blake Erickson) #16
I don’t know. I would download postman and maybe Charles see if you can get that working that way and it might shed some like on what your doing wrong.
I don’t think the quotes matter.
Make sure your Content-Type is set correctly maybe.
(Stefan Milenkovic) #17
ok, fixed it.
contentType : 'application/json’
and i was setting it only to contentType : ‘json’,
thanks!
(Kenny Meyer) #18
Where do I get the post_action_type_id for the opposite action (dislike) from?
(cpradio) #19
To remove a like you send a DELETE call to the post passing post_action_type_id of 2
As seen in the Network tab of Dev Tools
(Kenny Meyer) #20
Thanks. Where do you find the post_action_type_id?
