How to make it on the top?
(tony) #1
I am a moderator of http://forum.evol.net/ . Now i have a problem. I have pinned the post, but i can not make it on the top like another one on the top. how?
(Régis Hanol) #2
According to the edit revision history, it seems like you’ve pinned the topic while it was in a category and the moved it to uncategorized. Not sure that is supported. Have you tried unpinning and pinning it again?
(tony) #3
i have moved it to uncategorized and tried unpinning and pinning it again. It did not work. I guess if i did not have rights to do that unless the system identity?
(Régis Hanol) #4
Stupid question, but did you pin it globally?
(tony) #5
Done, i have to unpin it, then pined it globally again.Thanks a lot!
(Régis Hanol) #6
