How to manage categories on Home Page
(TheBurningMan) #1
See MPSocial Forum - https://mpsocial.com
I want to manage my forum page like this. Means On the distributing posts under category. Oops, Little hard to explain.
This is my forum which is installed currently - http://forum.buzzbasement.com
What settings should I choose to change homepage.
(Vinoth Kannan) #2
In top_menu SiteSetting re-order categories to first place.
(TheBurningMan) #3
I haven’t found this option :expressionless::expressionless::expressionless:
(Vinoth Kannan) #4
You can find it in this url yourdomain.com/admin/site_settings/category/all_results?filter=top%20menu
(TheBurningMan) #5
It works thanks. One things missed. How to choose which category should be above means category order.
(Vinoth Kannan) #6
By default it will display depending on recent activity. If you like to set the position search fixed category positions in SiteSettings search bar.
(TheBurningMan) #7
See this, but there is nothing regarding category order.
(Vinoth Kannan) #8
You already checked fixed_category_positions_on_creare setting. So you can set the order number in Category creation / edit dialog. I hope you know where to edit the category.
(TheBurningMan) #9
Yup, I found the option of category order. Thanks for your help.
(TheBurningMan) #10
123
I tried to change the order but it doesn’t work. Means it is not saving
(Vinoth Kannan) #11
It looks like working. I can see the changes in order.
(TheBurningMan) #12
Nope, I change it. I put latest news on the top and rearranged every category. But when I refresh page, everything goes back to normal again means same order.
(Erlend Sogge Heggen) #13
Did you click “Fix positions” and then “Save order?”
(TheBurningMan) #14
Yup, after clicking on “fix position” all category positions sets to default. And when I changed category positions, Save Order option didn’t work
(Viorela) #15
Hi!
Maybe i don’t understand how “Reorder Categories” should work, but in my case it’s showing the wrong order in All Categories drop-down.
The order I’ve set:
The order in All categories:
Screenshot_207
Did all of the above: Fix positions + Save order. Thanks!
#16
Have you these options checked in your settings?
If checked, you will be able to arrange categories into a fixed order. If unchecked, categories are listed in order of activity.
fixed category positions on create
If checked, category ordering will be maintained on topic creation dialog (requires fixed_category_positions).
(Vinoth Kannan) #18
Category list in the site.json is cached. So you may have to wait for sometime before it appear in the correct order.
(Viorela) #19
Yes, you are right. After a few refresh pages i was able to see the correct order.
@mikechristopher Thank you, i didn’t know about those settings.
