How to manage Database? Uninstall Discourse etc
#1
If I want to delete current DB and start Discourse all over from the beginning, how can I do this?
I want to know these basic steps: Uninstall/Re-install Discourse, Manage database, etc? or would you tell me what should I learn?
And one more,… where is the location of uploaded images?
Happy new year :smiley:
(Erick Guan) #2
  1. Backup.
  2. Delete /shared/app folder.(CAUTION: deletes the world)
  3. Restore or fresh start.
#3
I don’t have /shared/app folder, but /shared/standalone folder.
and what if I configured multisite?
(Erick Guan) #4
Well, cleaning /shared/* is just alright. If unknown, use Discourse backup and restore.
If you are on multisite, the database file and uploads will be separated.
Uploaded files are in web-only/uploads(multisite).
#5
Where is web-only…?
And do you mean if I want to delete only the second site… then don’t touch /shared but delete /web-only/uploads ?
I’m confused :dizzy_face:
(Erick Guan) #6
You don’t need to manage all the data manually at all.
Just backup and download all of data. Then
rm -rf shared/*
You can setup your new discourse since then. And inspect whatever files in the backup which contains all Discourse data.
#7
One more following question to clarify.
I want to delete only multisite (configured it with: Multisite configuration with Docker)
Then deleting this is right? or are there more folders & files to delete?
/shared/standalone/uploads/secondsite
(Kane York) #8
Yes, that should be close enough to everything.
