How to modify Login/Register Modal
(Douglas Teles) #1
I want to change style of modal, not only css, how to do that?
Thanks!
(Mittineague) #2
You want to modify the HTML in the modal?
AFAIK the current theming allows for
common - desktop - mobile
header - after_header - footer - head_tag - body_tag
but not for modals
You could put together a plugin to override the modal. Keep in mind it could be trouble to maintain.
Maybe adding modals to theming could be done?
(Douglas Teles) #3
I want change the modal html
