How to move from standalone setup to separate containers?
(Tuan Anh Tran) #1
Very much prefer if there is an easy to follow guide like the official one w standalone container.
(Jeffrey C Witt) #2
@tuananh I’m working on the exact same thing, with the hope of creating a guide. Right now I haven’t found a very specific guide. Here’s a description of my discoveries thus far. Running a separate data container.
(Theron Boerner) #3
Is it just possible to save a backup and then import to a new discourse? Is everything copied over?
(Kane York) #4
Yes, this is correct - once you have the new setup working, you can just restore a backup (followed by a ./launcher restart web_a && ./launcher restart web_b) and it will work.
(Jeffrey C Witt) #6
@tuananh
See my new "beginner’s guide"
https://meta.discourse.org/t/beginners-guide-to-setting-up-discourse-multisite-with-docker/17972?source_topic_id=17875
:smile:
(Brahn) #7
I managed to do this just recently. The most disconcerting thing about restoring from backup is that it appears to never finish. It works though :slight_smile: Also, it might look like the setting are not restored but a restart will fix that.
