How to Permanently Remove a Topic?
(Matheus) #1
Hi all,
I recently created a thread on my forum that was flagged as phishing by Google. I changed the thread title, thus the URL, but It seems that there’s still a historical of the old URL. Is there any way to permanently remove this thread, so the old URL is not accessible to anyone?
(Matheus) #2
I deleted the post, but admins can still see it.
(Nate D.) #3
As far as I know you cant delete anything (except when you’re doing a backup) over the gui.
(Kane York) #6
That’s admin-only - try opening a private browsing window Ctrl-Shift-N and viewing the topic.
(Jeff Atwood) #7
As @riking noted, it is deleted, it is only visible to staff now. Google won’t be able to see it and will get a 404.
To verify this for yourself, enter incognito mode (or use a different browser) and try navigating to that URL.
(Matheus) #8
Private browser still leads to the forum, but it says the URL is invalid or
visible for admins only.
That is the expected behavior, correct?
(Jeff Atwood) #9
Compare with a random URL you just made up like
http://try.discourse.org/t/not-found/9999999
Should be the same…
(Matheus) #10
Yep. Looks the same. Thanks for that.
