How to re-generate all topics?
#1
Hi. I’ve updated lazyYT plugin with the following data:
    - replace:
    filename: /var/www/discourse/plugins/lazyYT/plugin.rb
    to: data-ratio=\"16:9\"
Now I need all the topics to pick up changes (manual edit+save works fine). Is there an easy way of doing it in console?
Make lazyYT plugin responsive easily
(Kane York) #2
Enter the container, and run rake posts:rebake
cd /var/discourse
./launcher enter app
rake posts:rebake
logout
logout
This can be done with the forum running just fine. Note that it will cause lots of outbound traffic from oneboxes.
Broken images in production after importing backup
Importing from phpBB3
Converting to Subfolder
