How to remove 3 latest posts below categories?
Is there a way to remove the three latest posts from appearing below the categories on mobile’s main page? For example, on the mobile’s main page it looks like:
CATEGORY 1
Latest post one…
Latest post two…
Latest post three…
CATEGORY 2
Latest post one…
Latest post two…
Latest post three…
I’d like it to just have a list of categories on the main page, to keep it extra clean, and then users can click the category to go to its respected page. I know in category setting you can set it to 1, but not 0.
Thanks so much!
Something like this will do it (you can add CSS under admin > customize > themes)
.mobile-view .categories-list {
  .category-topic-link {
    display: none; // Hides topics
  .subcategories-list {
    border: none; // Removes extra border
    td {
      padding-top: 0; // Spacing fix
  h3 {
    padding-bottom: 10px; // Spacing fix
Thanks, that worked perfectly!
Do you have an equally easy fix to remove the “# total” and “# week” from each category?
If so, is it code I can put right below the code you sent, or does it need to be inserted into that somewhere?
Thanks!
