How to reset SSO from Hosted plan?
(Bgoldste) #1
Hi again, I’m on the hosted plan but would like to reset some of my settings so that I can play with the SSO. I’m not sure how to get into the launcher / cli stuff to do what’s described in the pinned topic.
Thanks!
(Sam Saffron) #2
If you need to reset it contact us, I went ahead and reset it.
I plan to add a magic route /admin/login that will allow you to log in (if you are an admin) regardless of sso state, getting it working right is a fair amount of work though.
To minimize your risk here, when doing sso testing always use 2 browsers with distinct users. You will remain logged in after you enable sso so you can always use that session to set SSO back to disabled.
(Battlesnake) #3
Was that magic route added? I added a load of OAuth and a logo image to a new site, and now when I click “log in”, I get taken to the same page with a long ‘sso’ URL query parameter added.
(Sam Saffron) #4
Yeah the magic route is in @techAPJ added it
(Arpit Jalan) #5
The magic route is /users/admin-login
(Battlesnake) #6
Thanks! I managed to turn SSO off via the ruby shell as advised elsewhere in the forum, but I’ll make note of that magic route.
