How to see and mass update user category watch/track/mute settings by group
(Tobias Eigen) #1
I’d be grateful for advice on a psql query for seeing and mass changing the category watch/track/mute setting for users, preferably by group. So I can see which users are e.g. watching a category, and also mass update their setting for a specific category based on the group they are in.
Thanks in advance!
(Jeff Atwood) #2
@techapj maybe we should have a howto for this?
(Tobias Eigen) #3
Thanks - would be glad to see a howto for automatically setting the category notification settings for everyone in a specific group. Or, better, the ability to set up regular queries to run for group members to mass update them, similar to badges.
I did some poking around using the new data explorer plugin (thank you!! :heart_eyes:) and am getting some insight into who’s watching certain categories.
I think this is the query to see who’s watching a category:
SELECT * FROM category_users WHERE category_id = '16'
I first got the category using this query:
SELECT * FROM categories
The results show “notification level”. 3 appears to be watching, 2 appears to be tracking, and 0 appears to be muting. I don’t know what 1 would mean.
I have one user with two entries in this list which I find a bit puzzling. Looking through the UI he is watching the category so the 3 is correct. Again, not sure what 1 means.
BTW: I can then look in the users table to see what the user ID is, but it would be handy if that link to “User #64” actually worked - right now it goes to /users/by-id/64 which results in a page not found error. Is that a bug?
(Kane York) #4
Yes, that’s a bug, can’t fix it right now as I’m on vacation. It’ll work if your name the column user_id as user$user (yeah… Will be fixing that too)
(Tobias Eigen) #5
This has come up again and is becoming an urgent issue for my community.
I’d be grateful for any advice on how to mass update user category watch/track/mute settings by group.
(Sam Saffron) #6
You would need to use the API for that.
Make members of a group watch a category by default
(Nick Putman) #7
I would also like to be able to do this - set watch categories and mailing list mode for members of a group at the same time. Where can I find more information on how to do this?
