How to set domain 301 redirects?
#1
The domain test.com 301 redirect www.test.com
I use discourse_docker
(Johnathan Nader) #2
Anyone figured this out?
(Mittineague) #3
Are you sure you need to?
The routing in Discourse uses the topic id (eg. 19976 for this topic) so if changes are made in the title and / or category links go to the right topic automatically.
Are you seeing Warning or Error messages anywhere?
(Joe Seyfried) #4
I guess the OP meant a redirect from example.com to www.example.com - not an internal 301 redirect. That should be an nginx related question.
(Sam Saffron) #5
The general gist here is to add a after_web hook that would amend nginx conf so it redirects, or maybe lay down a new file in conf.d for the redirect.
(Joe Seyfried) #6
Haven’t tried it, but my guess would be that if you take the solution from this question
into the server section of your conf.d/discourse.conf file, you should be fine (so start after the listen directive, overwrite the server_name, and put the redirect there). Note that you have to re-apply this when you rebuild your container (correct me if I’m wrong, @riking).
(Kane York) #7
You would do it in an
in your app.yml file, so the change is reapplied on rebuild.
Check out web.ssl.template.yml for an example of how to do that.
(Johnathan Nader) #8
So I edit this, and put this into it?
server {
    #listen 80 is default
    server_name www.example.com;
    return 301 $scheme://example.com$request_uri;
And then have to also update the app.yml file?
And then restart/rebuild it?
(Kane York) #9
Nope, that would be nginx -t followed by service nginx restart. Assuming you’re using a second nginx outside the container.
If you aren’t using that, you need a pups replace rule and a rebuild.
#10
I’m dense and slow. What am I adding where in a Digital Ocean droplet install to get rid of the dreaded “Redundant Hostnames” error in Google Analytics?
(Kane York) #11
Follow the instructions here:
then, on the outer nginx, add this:
file: /etc/nginx/conf.d/redirect-from-silly-domain.conf
server {
    listen 80;
    listen [::]:80;
    server_name www.sillydomain.com;
    return 301 https://discourse.yoursite.com$request_uri;
#12
Even in Digital Ocean installs? I don’t think there is a /etc/nginx/conf.d to mess with. I’ve looked and no nginx directory in there.
(Kane York) #13
You need to apt-get install nginx and set it up first, as discussed in that topic, and if conf.d doesn’t exist use /etc/nginx/sites-enabled .
#14
Roger that, just did the deed thanks. Redirect now works.
