How to setup multiple containers?
(Manthan Mallikarjun) #1
Hey! I just want to make sure that I am doing this right.
I have to copy this: discourse_docker/web_only.yml at master 路 discourse/discourse_docker 路 GitHub into the containers/app.yml file and then configure the info?
Then i have to setup a postgres server and put in the details into the app.yml file?
Where exactly does redis come in?
Im using AWS. The psql server will be on a micro instance and every ruby on rails server will run on a small server.
(Michael Brown) #2
The name app.yml denotes the name of the container. For only a single container (app), the name isn鈥檛 important.
In your case you鈥檒l probably want to have (for instance) postgres.yml, redis.yml, web.yml.
(Manthan Mallikarjun) #3
So I dont need to make an app.yml at all?
(Michael Brown) #4
Exactly. It鈥檚 just a name. Since you鈥檙e using the web_only template, perhaps the best choice for your web-only container would be web.yml?
The name doesn鈥檛 matter - it鈥檚 there for your convenience and use.
