How to show the "pen" tool in below each post?
Now the “edit this post” tool is usually hiden in the “show more” tool.
I want it to be there by default.
post menu hidden items is the setting you need from your admin section. Just remove it from there
if you look in post menu you should see it there also with all the rest and can reorder as you wish
They look different on differential forums, I think it is because the admins choose what goes in there
Great! I see.
Thank you.
