How to Stop Rails Server inside Discourse Container?
#1
Currently I am importing a big forum with limited hardware resources. What I want is to kill rails, redis, and sidekiq servers to make use of the most of the memory while importing the forum.
(Rafael dos Santos Silva) #2
You are doing a import using a docker container? I see people usually do this in a dev environment.
Anyway, inside the docker container you can run:
sv stop unicorn
sv stop redis
#3
This will kill sidekiq as well?
Thank you!
(Rafael dos Santos Silva) #4
Yes. Just tested it here.
