How to track searches with Google Analytics
(Camille Roux) #1
Hi,
I like to know how to track searches with Google Analytics.
Btw, are searches tracked?
Thanks
(Sam Saffron) #2
What searches are you talking about? Internal or external?
(Camille Roux) #3
Actually, I’d like the internal Discourse searches (with the icon in the top right of the page) appear in the Site Search section of Google Analytics.
(Sam Saffron) #4
hmmm … you would be dealing with some complex integration then. its probably possible to attach extra params.
(Camille Roux) #5
I don’t think so. To my mind, you just should send an event to Analytics using the same way than others pages (example: “/search?term=test”). After that, we’ll just have to define “term” as the search parameter in GA.
(Dean Taylor) #6
I would also be interested in seeing this implemented - perhaps re-categorising this thread into a “feature request”?
Google’s example to logging POST based searches is:
analytics.js: ga('send', 'pageview', '/search_results.php?q=keyword');
This method should fit well with Discourse’s search interface.
The Google Analytics documentation is here relating to search
https://support.google.com/analytics/answer/1012264?hl=en-GB
The settings in Google Analytics looks like this:
The example image also uses s for search query.
In the example image I have put in c and u as example extra parameters that might be used:
  • c = category based search
  • u = user page search
  • possible additional searches - but not sure about in-topic searches.
Not sure if this level of detail helps - but you can search many different things in Discourse - it would be nice to use Google Analytics to help visualise what users are attempting to get to from where.
Documentation mentions this:
In the Category Parameter field, enter the letters that designate an internal query category such as ‘cat, qc,’.
(Ivan) #7
So if I’m understanding this right, we just need to have a script that checks to see if we’re on the domain.com/search page, and then fire off a ga('send', 'pageview', '/search?q=keyword'); upon clicking search or hitting enter?
(Alex Armstrong) #8
Is this a thing? Is it possible to track internal Discourse searches with Google Analytics?
(James Cobalt) #9
Not quite. You could track those searches in Analytics easily enough already by URL parameter. The problem here is most of the searches probably don’t get to the search URL - the searches occur real time on the current page. Basically the script needs to post the search field text to Analytics after say, 2 seconds have passed since typing in it.
#10
Bump from the dead!
Is this right?
Not sure if simply putting q as a parameter is good enough, or if I need this whole /search?q= in there.
#11
I can potentially save you some work here. The new admin dashboard spec includes onsite search data. (I just need to double check with @eviltrout that we’re doing that part).
#12
could you mention me when its released?
thanks in advance
#13
I’d love to say yes but I can’t promise I’ll remember. It would be safer to follow this topic because I’ll update that when we’re done.
