How to translate?
(Frédéric) #1
Hello, I’m puzzled : some french translations are missing :
But when I go to :
https://www.transifex.com/projects/p/discourse-org/viewstrings/#fr_FR/serverenyml/40410709?translated=no
It don’t see “fr.admin.plugins.title”.
So probably, the missing translations are coming from elsewhere : I tried the curated plugin (docker install / uininstall ).
I don’t know. I’m puzzled. How can I translate this admin part ?
Thanks a lot !
(eriko) #2
Most, if not all, plugins are not in transiflex. They have their own language files.
plugin_name/config/locals/client.en.yml
plugin_name/config/locals/server.en.yml
you would need to add on a pull request to the plugin developer.
plugin_name/config/locals/client.fr.yml
plugin_name/config/locals/server.fr.yml
(Robin Ward) #3
Actually those keys should be in the main app, not the plugin.
@techAPJ any idea why those keys aren’t in Transifex? Is it because they’re in master and not stable?
(Arpit Jalan) #4
You are looking in the wrong file server.yml, instead you should be looking in client.yml. Here is the key you are looking for:
https://www.transifex.com/projects/p/discourse-org/translate/#fr_FR/clientenyml/40685021?key=plugins.title
(Frédéric) #5
Ok, many thanks for your help !
So, transifex explain that server.yml is fully translated in French
I can see the translation of admin.plugins.title : Log in · Transifex
But in my discourse instance, It is not translated. What have I missed ?
Furthermore, the admin.plugins.title.name does not exist, nor admin.plugins.title.installed, nor admin.plugins.title.version
So I clearly don’t understand how to fix this.
Can you please clarify ? Thanks again !
(Marcin Rataj) #6
@frederic missing keys happen from time to time in beta channel. :dealwithit:
Transifex is periodically synchronized with Discourse sources at /config/locales by the Discourse team.
I try to keep pl_PL translation for client*.yml up to date, but sometimes miss the window: I had the same missing keys for pl_PL with 1.2.0.beta9.
My workaround is to translate keys at Transifex (so that labels are fixed in next beta release) and use discourse-locale-override plugin to backport translations to my instance.
That being said, I would not don’t bother with missing labels in /admin, as they are not visible to regular users: I use mentioned plugin only if a user-facing label is missing. :wink:
(Frédéric) #7
Thanks for all !
Curiously, the translation is ok now. :smile:
To be honest, I don’t really understand what is happening and how it works. That will take time :smile:
Thanks again for your help and explanation
