How to update to Discourse 1.0?
(Sam Saffron) #1
Now that Discourse 1.0 is released, you’re wondering how to update your existing Discourse installation to the first non-beta release.
Move discourse docker from /var/docker to /var/discourse
Our official location for docker install has moved, we recommend you keep your install in /var/discourse as opposed to /var/docker
cd /var/docker
./launcher stop app
# Change all references to /var/docker to /var/discourse (volumes:...)
nano containers/app.yml
cd /
mv /var/docker /var/discourse
To search and replace all instances in nano, use Ctrl+\.
Update Docker
The latest version of Docker contains many urgent fixes, most notably, restart policies ensure your Discourse image will come back to life after a reboot.
apt-get update
apt-get dist-upgrade lxc-docker
Ensure you are tracking the desired Discourse branch
Discourse has 3 official branches:
  1. tests-passed: updated most frequently after our test suite runs. This is the branch we deploy most of our customers on.
  2. beta: updated weekly(ish), a snapshot of tests-passed.
  3. stable: where our major releases live (with security fixes backported as they arise)
Pick your desired branch. This find by editing the file nano containers/app.yml
params:
   version: tests-passed # or beta or stable
Update to the latest Docker image
Our newest Docker image resolves quite a few issues (log rotation, syslog works correctly, permissions, security), we strongly recommend you upgrade.
cd /var/discourse
git pull
./launcher rebuild app
Customize subject format for standard emails
Which branch of Discourse is used internally?
Renaming Discourse's root directory?
(Jeff Atwood) #2
(Michael Downey) #3
The instructions don’t say where to adjust params. :slight_smile:
(Michael Downey) #4
FYI, when I did ./launcher rebuild app I got about 20 or so blank lines over several minutes after
Pulling repository samsaffron/discourse
At which point I did a Ctrl+C and tried it again, at which point I got normal output.
(Jeff Atwood) #5
That is actually “normal”, though I don’t know why.
(Sam Saffron) #6
I will see if there is some way to get this to produce a sane output. It’s somewhat related to docker pull without crazytown control code central · Issue #3694 · moby/moby · GitHub but different
(Scott Shillcock) #7
I was wondering the same thing. So I went poking around and found it in app.yml.
cd /var/discourse
vi containers/app.yml
Starting at line 21, I see the following:
#params:
  #version: tests-passed
Since I want tests-passed the default works for me so I didn’t make any edits.
Update: Go here for a more detailed answer:
(@SenpaiMass) #8
hello any specific reason for moving /var/docker/ to /var/discourse/ ?
(Sam Saffron) #9
Branding, this is a discourse specific setup. /var/docker really should be reserved for general docker stuff.
(Zander) #10
I am getting this why i try the update:
Gem::Ext::BuildError: ERROR: Failed to build gem native extension.
/usr/local/bin/ruby extconf.rb
Cannot allocate memory - /usr/local/bin/ruby extconf.rb 2>&1
Gem files will remain installed in /var/www/discourse/vendor/bundle/ruby/2.0.0/gems/nokogiri-1.6.3.1 for inspection.
Results logged to /var/www/discourse/vendor/bundle/ruby/2.0.0/extensions/x86_64-linux/2.0.0-static/nokogiri-1.6.3.1/gem_make.out
An error occurred while installing nokogiri (1.6.3.1), and Bundler cannot
continue.
Make sure that gem install nokogiri -v '1.6.3.1' succeeds before bundling.
I am not familiar with debugging gem issues. Any help would be greatly appreciated.
(Sam Saffron) #11
Are you using our docker based setup?
(Jeff Atwood) #12
Out of memory. The update process puts unusual pressure on memory.
Run free -m. Add a small swapfile, as documented here.
(Zander) #13
@sam @codinghorror Yea I am using the “cheapo” option at the moment from Digital Ocean and the swapfile resolved the issue. Thanks.
(Jens Maier) #14
Upgrading my unsupported and dockerless Discourse instance more or less went like this:
discourse@majestix ~ $ scripts/upgrade
discourse@majestix ~ $ exit
:thumbsup:
(Daniel Hollands) #15
Would you recommend that people stay on tests-passed, or do you think stable is the better one to be on? What could I be missing out on by not using tests-passed?
(Alles ist erlaubt) #17
Debian users: Be advised this update will not work with the docker package available through official repos. After a git pull in /var/discourse, launcher will tell you docker 1.0.0 is no longer supported. You can use the script at https://get.docker.io/ to get a newer version. It will replace docker.io package with lxc-docker 1.2.0 (and add apt source etc.).
(Sam Saffron) #18
Yes, I just changed this, we have seen issues with earlier versions of Docker so I am using v1 to ensure everyone are synched on Docker 1.2.0
Docker is still moving fast and there are critical issues in various releases post 1.0 than needed addressing.
(Kane York) #19
If you’re worried about “missing out” on things, you’re probably one of the people who can run on tests-passed.
The whole point of beta and stable is to have more, well, stabliity.
(Daniel Hollands) #20
I’m thinking I’d probably rather track the stable branch then - don’t want to risk the community on something which might not be 100% (such as the bug last week which prevented people from posting messages)
(Jeff Atwood) #21
Yeah, but how long was that bug even present in tests-passed? An hour? So you can always update again, too.
