How to upload discourse to server using ftp?
docker
(A Tong Vy Binh) #1
I built success discourse.
How to develop this source and how to deploy to server?
(Felix Freiberger) #2
Discourse cannot simply be uploaded to a server – it needs to be installed. Just follow the official instructions that explain the process.
(Joe Seyfried) #3
I suspect you’re trying to upload Discourse to a shared hosting platform, which will not work. You need root shell access in order to “build Discourse” (i.e. install it), and this has to be done on the system where it will be running (i.e. your root server).
(A Tong Vy Binh) #4
Thanks for all answers.
But I just bought the hosting. I don’t have root privilage. :(. Are there noway to do that?. But not, any body can help me for any “question and answer open source” using PHP?
Thanks again !
(Tom Newsom) #5
Discourse does not use PHP; it uses Ruby and Javascript.
The easiest way to get Discourse up and running is Digitial Ocean’s one-click install.
The recommended $20/month package will work very well. It can be made to work well on the $10 package but that requires some extra steps. Nothing too complicated if you follow them word for word.
