How to use latest translations on my own discourse
(Eric Vantillard) #1
I would like to use the latest translation avaible on my discourse site.
How can I extract it from transifex ? and how to use it on my docker image ?
(Eric Vantillard) #2
I will check if I can customize my docker image using this script
To get new translations, we run a script6 that uses the client and does some post-processing to make sure everything is in a format that works.
ruby script/pull_translations.rb
extract from the HOWTO
(Eric Vantillard) #3
Maybe creating a new templates/translator.template.yml in the docker image and using an after_code hook ?
(Ilya Kuchaev) #4
What translations it’s pulling? I see the following strings in output
Skipping 'ru' translation (file: config/locales/client.ru.yml).
Thanks!
(Eric Vantillard) #5
Skipping means already up-to-date.
to use latest translations (even unreviewed) you need to change the command line used in the pull_translations.rb script:
command = "tx pull --mode=translator -a #{ARGV.include?('force') ? '-f' : ''}"
see transifex client doc http://docs.transifex.com/developer/client/pull
