How we do adsense with google dfp
(Mark Theis Madsen) #1
Hi.
Over on https://discourse.osmc.tv I have had some problems getting the adsense plugin to work. It simply didn’t work for us for some reason.
Instead I injected an ad in the DiscoveryView which is working quite well for us.
Adsense doesn’t support refreshing ads with ajax but adsense together with google dfp does!
I found this neat little jQuery plugin that makes it a lot easier to use dfp.
Include the script in </body> in the dashboard and then add this after:
Discourse.DiscoveryView = Ember.View.extend({
  _insertAd: function() {
    this.$(".list-container").prepend( "<div class='toplist_ad' data-adunit='ad_ID' data-size-mapping='toplist'></div>" );
    this.$(".toplist_ad").dfp({
      dfpID:'xxxxxx',
      sizeMapping: {
        'toplist': [
          {browser: [1100, 0], ad_sizes: [970, 90]},
          {browser: [810, 0], ad_sizes: [728, 90]},
          {browser: [530, 0], ad_sizes: [468, 60]},
          {browser: [0, 0], ad_sizes: [320, 50]}
  }.on('didInsertElement')
This will add a div and then add the ad into the div. It will show an ad on the list and category pages but not when on a topic. So the ad don’t fresh when you go from latest to top, but it does when you go from a topic back to a list. sizeMapping is for showing different ads on different window sizes.
I have made a few apps in Ember.js but Discourse is still way out of my league :slight_smile: . If anyone have a better/cleaner way to do this then feel free to add it here.
(Mark Theis Madsen) #2
@riking Just saw your edit.
Can you explain why that is better? Am I interfering with discourse using didInsertElement?
And why use an underscore in _insertAd ?
(Mittineague) #3
This is commonly used to signify “private”
