Howto bind discourse to a single IP address
I have a machine with multiple public facing IP addresses – I want to give a discourse instance only one of those IPs to bind to. I have found lots of stuff about putting discourse behind another server (apache, nginx) but was unable to find anything about letting it bind to :443 / :80 on just a single IP.
Put the IP address before the ports in the expose settings in app.yml.
When reading the docker documentation for expose, it didn’t seem like IP was an option?
app.yml does not universally follow Docker naming conventions, because in many cases launcher pre-dates the equivalently named Docker feature. The expose stanza in app.yml corresponds to Docker’s --publish option. You can verify this by reading the ./launcher source, and how it deals with the expose stanza.
Thanks much. For those who might come here looking for what to change.
expose:
  - "80:80"   # http
  - "443:443" # https
to
expose:
  - "{public_ip}:80:80"   # http
  - "{public_ip}:443:443" # https
then to get the changes to take I did a
./launcher rebuild app
Question: could I have done a bootstrap instead of rebuild?
The faster method here is a restart replacing a rebuild.
