I can not enable the docs plugin
Hi,
I am using the 14 days free trial. I can check the enable icon in the docs plugin settings, but the enabled action can not be saved. So the docs plugin can not be enabled.
How to enable the docs plugin?
Thank you,
Frank
It works, I must double click the enable icon.
