I get error response from daemon: when rebuild Discourse
(Sora &\) #1
Today, i install plugin, when i run “./launcher rebuild app command” , i get error below:
root@bdser:/var/discourse# ./launcher rebuild app
/usr/bin/docker: Error response from daemon: connection error: desc = “transport: dial unix /var/run/docker/containerd/docker-containerd.sock: connect: connection refused”: unknown.
ERRO[0000] error waiting for container: context canceled
Your Docker installation is not working correctly
See: Docker error on Bootstrap
What next can i do to fix it?
Thank you!
(Felix Freiberger) #2
It looks like your Docker installation is having problems. Docker isn’t entirely stable, this can happen occasionally. I’d first try running systemctl restart docker.service. If this fails, try rebooting the system :slight_smile:
(Sora &\) #3
Thank you! @fefrei
you solve my error :slight_smile:
