I got an error after updating my forked install
I typed the command as follows
cd / var / discourse
git pull
./launcher rebuild app
I got a caution statement like the following
You will less than 5 GB of free space on the disk where / var / lib / docker is located.
Filesystem Size Used Avail Use% Mounted on
/ dev / vda 1 25 G 20 G 4.4 G 82% /
(Y / N) y (y / N) y Would you like to try to recover space by cleaning docker images and containers in the system?
WARNING! This will remove:
        - all stopped containers
        - all networks not used by at least one container
        - all dangling images
        - all build cache
Are you sure you want to continue? [Y / N] N
If the cleanup was successful, you may try try now now
Based on the following topics
I typed the following command
sudo ./launcher rebuild app --skip-prereqs
I am having trouble keeping the site down.
Please tell me how to deal with it!
I have backed up my site before doing sudo ./launcher rebuild app --skip-prereqs
Why did you answer N and cancel the cleanup? That should make space for you to rebuild without using --skip-prereqs
After doing “./launcher rebuild app --skip - prereqs”, the site did not open and I ran “./launcher rebuild app” and chose y …
Is there a way to restore the site?
Were you able to make space to complete the rebuild?
If the rebuild failed and it didn’t delete the old docker image then you can probably just
cd /var/discourse
./launcher start app
To get back to the old version, but you clearly have a storage issue you need to tackle.
./ launcher start app
With the commands above the site is now to stand up, Thank you very much.
How can I update the site after all?
I’m sorry for the novice question.
After launching, I typed the following command again, but this time the warning message was not displayed and started rebuilt, and the site did not open again.
git pull
Currently the site is standing up with the following command again.
Still don’t know how to fix this :sob:
How much space does your server have in total?
Where are you using it?
We can’t even begin to advise you on this without some information to go on. It may well be outside the scope of the support we provide here, but without some data it’s impossible to even say that definitively.
My DigitalOcean’s droplet is “1 GB Memory / 25 GB Disk / SGP1 - Ubuntu 16.04.4 x64“ :slight_smile:
Does anyone know the way to fix a storage issue which what happend to me :sob:
This is a server maintenance issue as opposed to a Discourse issue.
Use df whilst connected via SSH to look at free vs available space - what else do you have on this server? How big are your backups?
The result of df.
Filesystem     1K-blocks    Used Available Use%
udev              498688       0    498688   0%
tmpfs             101604   10840     90764  11%
/dev/vda1       25227048 8893416  16317248  36%
tmpfs             508012       0    508012   0%
tmpfs               5120       0      5120   0%
/dev/vda15        106858    3437    103421   4%
tmpfs             101604       0    101604   0%
overlay         25227048 8893416  16317248  36%
shm               524288       8    524280   1%
The size of backup of my site is 57.1MB
According to that you’ve got 16GB free, which is plenty. You should be able to upgrade fine without problem now.
cd /var/discourse
Once you’ve done the above there’s no need to do another upgrade on the web interface, this will do it all.
hmmm… it does not also work…
FAILED
Pups::ExecError: cd /var/www/discourse && su discourse -c 'bundle exec rake db:migrate' failed with return #<Process::Status: pid 10681 exit 1>
exec failed with the params {"cd"=>"$home", "hook"=>"bundle_exec", "cmd"=>["su discourse -c 'bundle install --deployment --verbose --without test --without development --retry 3 --jobs 4'", "su discourse -c 'bundle exec rake db:migrate'", "su discourse -c 'bundle exec rake assets:precompile'"]}
150075aac134b18e5415078c15bcb72aa29e947e42310acc34e0b9b9e89ff95e
** FAILED TO BOOTSTRAP ** please scroll up and look for earlier error messages, there may be more than one
When I did “git pull”, it showed “Already up-to-date”. Is it relevant to this problem?
What version is specified in /var/discourse/containers/app.yml
Is it tests-passed? or something else?
How did you install Discourse? Did you follow the official installation guide?
Version which is written in /var/discourse/containers/app.yml is “tests-passed”.
But this is commented out by default.
#version: tests-passed
Yes I installed Discourse followed official installation guide.
I have already managed site for 3 months without any such update error.
Is this error perhaps what I should fix in ./launcher rebuild app?
2018-11-10 20:57:05.046 UTC [85] postgres@postgres ERROR: database "discourse" already exists
Hmmm still confusing
That’s an odd error. Have you rebuilt more than once?
We used to see that when people did the postgres upgrade and it failed, right?
Yes I had rebuilt several times :disappointed_relieved:
