If login required to view a topic, is the topic essentially noindexed?
#1
I’m setting trust level 1 required to view topics, so login is required to view topic content.
By doing this, does that mean that the topic content isn’t indexed by search engines? If not, how can I make this the case?
(Felix Freiberger) #2
As search engines will not login, everything requiring login is not indexed.
If you want to prevent the whole site from being indexed, you can uncheck allow index in robots txt in site settings.
