I'm getting an error 4 error 2 warning
(Hakan) #1
I did not set up ssh but I did not set up a new discourse. But I take these mistakes.
hata2
and chrome error.
hata
(Felix Freiberger) #2
Which instructions did you use to install Discourse? Are you using any plugins?
(Hakan) #3
Im reinstall but any error.
Plugins quick message, dlstaticpage and sidebar block
(Felix Freiberger) #4
Do the errors also occur in Safe Mode?
(Hakan) #5
safe mode I do not have any problems when I disable the plugins, but I need to install the plugin. installed add-on only topic-list-preview.
Whatever plugin it is, it gives this error. tags 404 error
(Felix Freiberger) #6
In that case, you’ll probably want to discuss this here:
