Image are not imported to discourse
Hello,
I create some post from old cms (i have xml file) with api. I convert the html to markdown.
All is fine but I have this last issue with image.
Image are not download to my discourse.
I had check download image
I use rake post rebake
I try rebuild html
But image are never download (and change to my new domain).
The image are create like this in my post
![1](https://www.hyper-convergence.fr/wp-content/uploads/2017/09/Steve-Chambers.jpg)
Image :
How I can force to download image to my discourse and change url into the post ?
There are several possibilities. There is a site setting that determines how old a post can be and have the images downloaded.
@pfaffman I don’t see in my discourse the setting with maw age for remote image.
I check download remote image.
Perhaps I don’t use the good mark to add image into my post.
As you can see here image is broken in my original post.
I’m not sure but I would try putting just the raw url on a line by itself. Not in markdown.
