Image Compression and Profiles
(Dean Taylor) #1
Continuing the discussion from Image Embedded Color Profile:
I noted the following updates: in WordPress 4.5 they will be making the following changes:
Increased image compression for custom sizes
WordPress 4.5 increases the amount of compression applied to intermediate sizes by changing the default quality in WP_Image_Editor from 90 to 82. As noted in the proposal for this change, this results in a noticeable reduction in file sizes with little change in visual quality. Developers can override the default image quality value using the wp_editor_set_quality filter.
Improved resizing settings for ImageMagick
For sites making use of ImageMagick, we’ve reduced file sizes further by resizing images more efficiently in WP_Image_Editor_Imagick and by stripping extraneous metadata using the new WP_Image_Editor_Imagick::strip_image() method.
For now, ‘icc’ and ‘icm’ color profiles are retained, along with ‘exif’, ‘xmp’, and ‘iptc’ profiles, which can contain copyright and orientation data. Those who want to retain additional metadata can disable profile stripping by adding a callback function to the image_strip_meta hook that returns false.
Note that the original full sized images uploaded to WordPress are unaffected by these changes.
Relevant code stripping image profiles:
My thought was that it would be good to share the research and possible optimisation cases.
Also noted there was some an Image Embedded Color Profile issue this might be relevant to.
Further WP conversation on this:
