Image zoom does not work
#1
When I upload image file on my forum, the image shows up.
But we cannot zoom the image if we click it after uploading.
Is there a setting for it? I can zoom images in other forums.
Thanks!
(Penar Musaraj) #2
Do you have a link to your site? Clicking on images works fine here on meta.
#3
sorry it’s a private forum. but yeah I know it here, that’s why I wonder how…
Basically it should be working so automatically?
(Jeff Atwood) #4
This implies sidekiq is not working or broken on your instance.
#5
If so, discourse dashboard should say that sidekiq is not runinng, correct?
(Glenn Sims) #6
If an image on your forum is shrunk to fit in the post window, you can click to zoom it in. If it’s actual size, you can’t click it to zoom in.
#7
Ahh I see, so it depends on the size.
(Glenn Sims) #8
This image’s natural resolution is 3113x1486 pixels. You can click it for a full size.
This image is 300px square. It fits in the post window perfectly and is already actual pixel size.
sim
#9
I understand it, thank you!
(Glenn Sims) #10
Feel free to mark as solved :blush:
(Glenn Sims) #11
To add, some images can be enlarged on the mobile site and not on the desktop site due to the sizing constraints of a phone screen. If that is the case, there’s no technical problem going on.
(system) #12
