Images could not load
Hello,
as the screenshot above images could not load, or let say i’m getting a 404. I have moved the site to https with let’s encrypt, and that :80 port in the end makes me doubt something about this issue.
I have done a rebuild
rake uploads:recover
also rebake,
but nothing changed.
Any idea about this issue. Running the latest release.
Thanks in advance.
The port should never appear in the URL except for local development instances, this implies you have an invalid configuration. Discourse only supports running on the standard HTTP/HTTPS ports.
With discourse installation or SSL certificate configuration?
Thank you
I believe if you search you can find information on the dev oriented port setting. It should not be set in a production install of Discourse as Discourse only supports running on the default ports.
restored from the backup, thanks for your help! :grinning:
