Images in drafts and queued posts are cleared to aggressively
(Sam Saffron) #1
(categorizing as bug, cause the queued post case is clearly a bug, draft arguably a feature)
If you have images in drafts or queued posts they are deleted 1 to 2 hours later. clean_orphan_uploads_grace_period_hours
This behaviour makes it very hard to use queued posts, and very difficult to compose drafts with images.
I suggest:
  • Increasing default upload clear to say 2 days or so
  • Adding queued posts
Drafts are clearly a more complicated beast, ideally images in drafts should only be visible to the user who is making the draft until draft is finally public.
cc @zogstrip
(Régis Hanol) #2
Fix just in :pizza:
Is there a way to delete old/irrelevant uploads?
(Jeff Atwood) #3
