Images in topic appearing in negative
I’m experiencing an issue whereby sometimes images posted in a topic are appearing in negative. If the image is clicked to view then the image appears as expected.
I’ve tried to upload the files individually from my documents as well as copying from an existing article on our website and the issue occurs using both methods.
Does the issue occur in safe-mode?
your.site.com/safe-mode
Does it occur if you try to post the same image here on Meta or on try.discourse.org?
Can you post a link to a topic where you’re seeing this issue?
Very likely to be a peculiarity of those images in my opinion. Can you repro this with a random jpg image?
