Images no longer getting lightboxed part 2
(Nathan Rijksen) #1
Continuation of
https://meta.discourse.org/t/images-no-longer-getting-lightboxed/14965?source_topic_id=21474
As that topic got locked without a proper solution.
I am still getting this issue even after updating to stable and doing a full rebuild. Eg:
Images no longer getting lightboxed part 3
(Jeff Atwood) #2
We simply can’t reproduce this – is anyone else reporting the issue?
(Nathan Rijksen) #3
Is there anything I can do to debug this myself? I assume it’s client-side code, can I enable non-compressed JS and run it through the debugger?
(Jeff Atwood) #4
Did this ever get resolved one way or another?
(Jeff Atwood) #5
(Jeff Atwood) #6
We finally found out this is likely due to a DNS problem in your Docker container @naatan.
Put your DNS server in /etc/defaults/docker.
