Images not ending in image filename extensions do not onebox
(Tyler Gillies) #1
Images like this don’t upload: http://cdn.donpark.org/i/78049b
(Sam Saffron) #2
Not following
(Tyler Gillies) #3
How did you do that? Did you manually need to put in img tag html?
(Tyler Gillies) #4
(Tyler Gillies) #5
AHA!
(Sam Saffron) #6
There is no bug here, we can’t tell from the URL that its an image so we don’t “onebox it” if it ends with .jpg we would.
(Tyler Gillies) #7
Ah, gotcha ok so it’s a url parsing thing gotcha! Thank you :smile:
(Kane York) #8
As a workaround you can add stuff like ?format=.jpg if you’re sure it’s an image.
(Tyler Gillies) #9
Hell yeah :smile:
