Images not found: no method: url (local ubuntu install)
(Jonathan Feist) #1
I’ve got a local ubuntu install (0.9.9.7) set up running in development mode with rails server (and also had to run redis-server separately).
When I right click and open an image with a dynamically routed path in a new tab I get the following error page:
Maybe I’m running the server under hacked conditions I don’t know, and I’m not expecting an answer. I’m just posting for archive’s sake and if I ever find out what I’ve done wrong. Or of course, if you know what I’ve done wrong, please let me know.
(Sam Saffron) #2
do you have image magick install (try running convert from the command line)
(Jonathan Feist) #3
Yeah it wasn’t installed. Solved by sudo apt-get install libmagickwand-dev imagemagick
(Jeff Atwood) #4
