Images paths are wrong in the welcome message
(Camille Roux) #1
Hi
All the images paths are wrong in the welcome message. How can I update it? (I need the french version)
Here is an example:
Thanks
(Jeff Atwood) #2
If it was translated earlier it needs to match the current English image paths.
(Camille Roux) #3
Can I copy/paste the new text from transifex?
(Nate D.) #4
I had to delete {base_url} (or something similiar, can’t remember) from every img url.
(Jeff Atwood) #5
This is not correct. The names changed, not the path.
(Nate D.) #6
When I removed {base_url} I had the englisch images loaded correctly.
Just to clarify: It was something like this after the setup of discourse:
<img src="{base_url}/images/welcome/topic-list-select-areas-2x.png" width="593" height="59">
And after the deletion of {base_url} the image was loaded correctly.
(Camille Roux) #7
I think it’s safer to remplace {base_url} by the URL root of your discourse, mainly when it’s sent by mail.
(Nate D.) #8
Isn’t that sent per private message? Ah and when the user isn’t online it gets sent per email right? Sorry I am fairly new to discourse.
