Imdb embeds broken on other sites
(@SenpaiMass) #1
Over here the embeds are working fine . for example you can see the image of the imdb link
But here
@ try.discourse
Also i am getting the same problem on my site
(Jeff Atwood) #2
IMDB is blocking people from getting images by referrer most likely. I see the image working, but then after I refresh the page, broken. @techapj can you have a look? Last time I checked IMDB was pretty strict about allowing any of this… but maybe they support opengraph or oembed by now.
(@SenpaiMass) #3
Could there be a fix for this or it’s going to be that way since IMDB is strict with their policy?
(Jeff Atwood) #4
Could be either, IMDb is quite strict, @techAPJ will check into it.
(Arpit Jalan) #5
I am unable to repro the IMDb broken image issue here on meta, try or locally… :confused:
Yes, IMDb does support Open Graph which is what we are using for extracting image and other metadata.
(@SenpaiMass) #6
IMDB embeds are still broken as of now :frowning:
(@SenpaiMass) #7
@techAPJ a fix is possible sir ?
(Jeff Atwood) #8
He could not repro the problem.
(@SenpaiMass) #9
I am not sure if the issue is fixed or not but its working fine for me.
PS- i recently added a SSL certificate to my forum , without https the imdb image was broken but with https://mysite.com i am getting the image perfectly.
http://i.imgur.com/cAF8Leu.png
(Sebastian) #10
Also broken on one of my discourses… could there be a fallback solution (displaying a generic imdb logo instead)?
(Arpit Jalan) #11
I can repro this issue on try.discourse.org, added on my list.
(Arpit Jalan) #12
Hmm, I have been looking into this issue for a while and I can’t figure out a way to bypass IMDb referer limitation.
This Stack Overflow answer best describe this issue: html - Remote images displaying only sometimes - Stack Overflow
Any suggestion(s) for fixing this issue is most welcome.
(Jeff Atwood) #13
You might try emailing them and ask if they ever plan to support OpenGraph or oEmbed to get an official answer Arpit.
(Robert) #14
Images from imdb are loading as long as I am on https. Otherwise, I get a 403 forbidden status code for the embedded image request.
#15
I’ve done quite a bit of IMDB (and Rotten Tomato) test embeds recently on Discourse.org and Try and I noticed that IMDB shows broken images sometimes but on other occasions is just fine. And by that I mean with the same embed - it’s as if something was changing IMDB’s end. It was this inconsistency that made me check out Rotten Tomatoes which works well.
Either way I don’t think either embed looks particularly nice - leading me to think that for now, an image embed followed or preceded by a text copy and paste might work better. Although I guess there maybe copyright issues doing it that way.
(Robert) #16
Wouldn’t it be preferable then to just write a custom OneBox even though
oembed is supported? However, this solution might only improve the
layout/design. It doesn’t help to fix images.
Did you encounter issues during your tests with Discourse on https?
#17
Perhaps, although I can’t see myself writing or modifying plugins anytime soon.
As an aside I do like the way iFramely handles embeds and note that NodeBB supports iFramely accounts.
No, all plain Jane http.
Previous Replies separator is not RFC-compliant
(Robert) #18
Going for iFramely is like out-sourcing the integrated OneBox API to a paid
service. I don’t like that. :expressionless:
#19
Then you have what you want already.
(Clay Heaton) #20
Looks like these are still broken on some sites. I just rebaked the linked post and the images still don’t appear (@codinghorror). Does it have to do with a CDN perhaps? They seem to work here…
