Implementing BlockAdBlock Script?
What would you like done?
On our forum we are showing google ads. Due to adblocker we are generating less revenue.
So, we need to implement BlockAdblock script in discourse.
When do you need it done?
Within two days.
If anyone can help, Please PM with your budget.
You have more chance of success if you indicate your budget.
If you can help PM with your budget.
As Iā€™m sure you know from the line which you deleted from the template, your initial post here should contain your budget.
Yes we request @hemanthchowdary1234 if you could post your budget as some developers have higher thresholds than others for being able to take on work.
