Import Questions
(Mr. Revrag) #1
OK, so I’m having some issues importing from Xenforo to Discourse.
I installed Discouse with the Docker container and was working my way through these instructions:
I have mysql installed and the Xenforo database imported to it.
Problem: when I run “bundle install --no-deployment” (after adding mysql2 in the previous step) I get a couple of errors. The first is that I shouldn’t run it as root and the second is: “Your Gemfile has no gem server sources” and suggests I add ‘https://rubygems.org’. Where do I add this.
EDIT… OK so it appears there are several “Gemfiles” . Do I add mysql2 to the one in /var/www/discourse?
